Other Parts Discussed in Thread: TPS54202
Hi
On the datasheet, there are mentioned about high side overcurrent protection and low side overcurrent protection.
How does these protection work when the output is shorted to ground?
Also, do you have pin to pin short and open test data for TPS54335?
I found the following post.
Could you provide us the data if you have? (Our customer would like to get these data.)
Koji Hamamoto
