Is it possible to control Vout of TPS7A84/TPS7A84A by MCU by tying the ANY-OUT pins to GND using Analog Switch? Or directly connecting Open Drain Digital Output?
What are requirements for such control signals?
Thanx,
Eli.
Thanx,
Eli.
Thanx, Kyle.
I consider to connect SPST Analog Switches (or MOSFET) to GND to each ANY-OUT signal. Can you tell what maximum Ron value will do the output voltage programming to precision of 1.5%-2%?
