Hi Team
Now I using BQ78350R1 for some customer Battery Pack.
And Customer want to control GPIO_A by Host Control ,
But I tried to this GPIO_A control by BQstudio with GPIO Config.
We setting for
GPIO Configration => GPIO A (Bit 6): GPIO A 1 = Active as GPIO
GPIO Output Enable => GPIO A (Bit 6): GPIO A 1 = Output
GPIO Default Output Enable => GPIO Tyupe GPIO A (Bit 6): GPIO A 1 = If enabled as Output, High
GPIO Type => GPIO A (Bit 6): GPIO A 1 = Open Drain
* Open drain and pulled up to 2.5V with 4.7kohm
Is this correct setting ??
We want to control with Toggle High / Low .
Dose we need other setting or Toggle Command ?
Jasper in Japan
