Other Parts Discussed in Thread: TLV431
Hi Team,
do you think it is possible to use a inverting charge pump like LM2776 to go from -5V to +5V?
Simon
Hi Simon,
A conceptual circuit using boost converter to generate +5V from-5V is shown below. If high accuracy of 5V is needed, it needs an external shunt regulator like TLV431 to regulate the output. What is the application and what is the output current in the application?
thanks
Gavin
