On startup, the SW output doesn't get to 1.8v. Instead, it exhibits a sawtooth pattern and eventually stabilizes around 1.2v.
We're using BAT input only (no VIN connected).
You can see the SW output after the inductor above and below the inductor (right out of the BQ) below:
This is a closeup of the SW output (first few cycles after power up):
This is the schematic:
Note that this is a Rev B of a design that already worked fine before. Nothing was changed in the BQ area - I'm trying to troubleshoot what would cause SW output to behave like that.
