I need to calculate TPS54160(a integrated MOSFET IC) power loss.
In datasheet, the IC's power loss calculation formula is given, and I use the webench to simulate the IC power loss.
I find the result have a gap between them, the webench's power loss is much bigger than the datasheet formula.
So I test EVM, the webench is right.
When I change the formula(55) 's parameter 0.25 to 0.9, the result is same.
Is the datasheet's formula or parameter have mistake? Or the TPS54160 working in a higher switch time in a period?
