BQ24195L: BC1.2 function
Part Number: BQ24195L
Any solution to disable BC1.2 function in BQ24195L? thanks!
  • Hello Ray,
    Are you referring to the D+/D- portion of the bq24195L? If so, this functionality cannot be disabled. If D+/D- detection is not required in the application, the logic state of the D+/D- pins can be fixed to set a default input current limit that fits the application. Table 2 and section 8.3.1.3.3 of the bq24195L datasheet has the details for this.
