The TPS62135EVM-698 uses a TPSE686M025R0125 68uF tantalum cap on the input rail.
This part is very expensive. Can I get a recommendation on using a lower cost part(s) with similar performance?
I have used aluminum electrolytic caps in the past on inputs to DC/DC converters. Another option would be to use three 22 uF, 16V 1210 caps in parallel. My input rail will be between 5V and 12V.
Thank you,
Bob
https://www.digikey.com/products/en?keywords=TPSE686M025R0125
