In the TPS621x0 datasheet there is in the application section a minimum value for the bottom FB divider of 400kO.
In the similar TPS821x0 module datasheet the minimum recommended value for the lower feedback divider value is 100kO
Given the similar silicon used in the two, what is the origin of the limitation and where is the x4 difference for the recommended value originating?
Thank you
