i'm trying to configurate the BQ40Z60 with the battery-studio as a standalon-charger for a 4S-LiIon-pack.
How is it possible to enable the internal Charge-Controller?
I attached the register-view.
Hi Onyx,
I found out that it is possible in manual FET-control (FET_EN = 0) to charge the cells. Therefore I enabled the charger and turned on the CHG-FET. So the buck-converter is working with the right current (1 Ampere) and this is also displayed on the current-meter in the battery studio.
But as soon as I go to firmware-FET-control (FET_EN = 1) both the charge- and the discharge-FETs are turned off. Only the the step-down converter is working but no current can flow in the cells, as the FETs are off.
Do you have any Idea what is stopping the charge-FETs from turning on?
Thanks for your support,
Felix
