Other Parts Discussed in Thread: PMP4397
We are using "BQ24133RGYR" as per PMP4397 Reference Design. However we need to give charger connection status to the circuit at LOAD. The issue we are facing is that there are 3 GNDs in the System. These are:
1. GND_BATT
2. GND
3. Pin-1 of J1
The circuit at load is referenced to GND_BATT, while the CHGSTATUS (STAT Pin) is referenced to GND. Due to the different GND references, the CHGSTATUS (STAT Pin) is not being read correctly by the circuit connected to LOAD. Please suggest a resolution for the same.
