Hello.
I have a problem with use bq24032a. It is not charging the batterry. I madea test scheme which I connected ISEL1 pin to ground throuth 1k resistor, PSEL and CE pulled-up, DPPP pin to ground throuth 1kk resistor. Thus, i carry out all conditions (as far as I could understand them from datasheet) to start charging (Vin 5v). But charging does not begin. However, I can supply to a load from out pin in both cases(battery or external power supply).
Please, tell me where I wrong.
