TPS659037: The differnce of TPS659037x
Part Number: TPS659037
Hi
Could you tell me the difference of TPS6590376/7/8/9?
Yokota
  • Takahiko,
    Thanks for reaching out to us. The TPS6590378/9 have an updated power-down sequence that more closely matches the AM572x power sequencing. Specifically, VDDS18V was moved to its own slot at the end of the power-down sequence, after DDR powers off.
    TPS6590378 is the updated version of TPS6590376, and TPS6590379 is the updated version of TPS6590377. Both are pin-to-pin compatible replacements, and are recommended for new designs instead of the older devices. Existing designs can continue to use TPS6590376/7.
    Thank you for using E2E.
  • Hi Gordon-san
    Thank you for the reply.
    How were them update from TPS6590376/7 to TPS6590378/9?
    Yokota
