Hi All,
When the current limit is reached, the FET turns off.
How is the cancellation of the limit state ?
If the current gets lighter, will Switching work again ?
Or must you turn the EN pin OFF / ON ?
Koji Hayashi
Hi All,
Koji Hayashi
When the current limit reached, the FET turns off. if the load is heavy which makes the Vo drops, if Vo drop to a level higher than Vin, then it can recovery, if Vo drop to a level even <=Vin, it can't recovery. you must turn the EN OFF then ON again.
