LP8863-Q1: Reseting the IC
Part Number: LP8863-Q1
I am looking for way to reset the IC. So far I only know POR, but is there any other way? Does toggling the EN pin resets the IC?
    Only way to fully reset the device is by toggling VDD supply and going through POR as you mentioned. EN pin low will only set the device in standby mode which will disable all analog blocks to save power, so boost will not switch and LED drivers will be disabled, but interface I2C/SPI will still be available in standby mode.
