TPS55340: Snubber for SEPIC
Part Number: TPS55340
Hi
Our customer is using TPS55340 with SEPIC topology.
However there are some ringing on the SW node. And it appears as the VIN noise also.
How can we reduce for the ringing?  Do you think the snubber can reduce the noise?
If it so, where should we put the snubber? (between Vin and SW?)
Could you give any advice if you have other way to reduce the noise?
Koji Hamamoto
