TPS5401: can be used inverting power supply?
Part Number: TPS5401
Other Parts Discussed in Thread: TPS54040
Hello
My customer intend to create inverting power supply 7V~20V input -15V 100mA(max) output refer to slva317b.pdf " Create an Inverting Power Supply From a Step-Down Regulator " .
Customer's  candidate is TPS5401 because it has low price ( lower than TPS54040) and also conventioval peak current mode control
Customer hopes to buy TPS5401EVM ( 3 EVM) now , but customer want to have your confirm prior to buy them.
Application is audio products, so customer need to sync control.
Attached ppt is power diagram.
Would you please confirm / advise about this?
Can  TPS5401  be used as inverting power supply?
Thank you for your support
Best Regards
inverting_buck_boost.pptx
