LM3410: What if feedback resistor fails -open?
Part Number: LM3410
Hello Team,
While using LM3410, what will happen when feedback resistor will fail-open?
How to handle this condition so that device is not damaged?
Mahendra.
  • Hello Mahendra,
    That is a good question. I haven't tested it, but likely due to leakage through the LEDs the FB pin will be pulled up and the device will stop switching. I think the only danger might be damaging the FB pin from the initial transient. But that could be easily protected with a zener to prevent exceeding abs max.
    Clint
