Other Parts Discussed in Thread: TPS23861, TPS2384
The customer is evaluating TPS23841.
There is a note on the datasheet Table7 (highlighted with yellow bar below) which is about port enable/disable registers. It has been observed that ports cannot be configured when the register is set. The customer wants to use the IC on SAM mode and enable/disable the ports when needed.
Could you please give more information regarding this implementation? (as mentioned on datasheet below, this information can be given by factory)
Mete
