Other Parts Discussed in Thread: CSD17484F4
In your load switch, TPS27081A, what is the gate capacitance(or charge at voltage) of the high side p-channel fet. A pullup resistor(R1) is required to turn off the p-ch fet, and I need to be able to estimate the time for its gate capacitance to discharge whenever the low side n-ch fet turns off. The closest parameters that I see in the datasheet specify the times for the load capacitance to discharge, which is not what is needed.
