Hi Guys, quick question - does the LP55231 enable line have an internal pull-up? If I leave it floating will the IC power on OK? Or do I need to pull it to Vcc?
Dave
Dave
Thanks Summer. One quick follow-up Q: Is it possible to turn off the Charge Pump and just run the driver in normal 1x mode? i.e. to reduce noise caused by the 1.25 MHz Charge Pump switching?
Dave
