I am designing a system that intermittently draws around two amps from a 3.3v LiFePo4 battery.
The system has a solar panel attached in order to charge the battery.
The solar panel may or may not have sufficient power to power the system.
For other BQ241xx Battery Charger ICs , TI indicates that system power can be tapped from the "up side" of the current sense resistor.
In the bq24650, that point is connected to the SRP pin.
Do you see a problem with using the bq24650 in this fashion?
Thank you
