BQ76940: Diagnostics and failure rates
Part Number: BQ76940
Battery monitor team,
A customer using bq76940 needs to know the following:
1. Is there an analog comparator used for Overvoltage?  By the wording in the datasheet, it sounds like it is handled through an ADC and a digital comparator.  Can you confirm?
2. Does the bq76940 run diagnostics on internal clock, internal supply voltages and temperature?
3. Considering the failure mode where DSG and CHG are stuck high - what is the rate of occurrence? Do we have an RPN# for this mode?
Darren
