Part Number: LM25116
do we have any app note / step by step guide for compensation? Customer uses an LM25116 and has some problems with subharmonics.
Regards, Holger
Regards, Holger
Hello Holger,
I am assuming you are referring to an output filter. It is not recommended to place the Double pole of the filter inside the loop BW of the feedback control, if you do, the system will be very difficult to compensate.. Please follow the guidelines given in the presentation attached. By doing so, you can ignore the LC filter at the output.
Hope this helps?
Output Filter design rev 2.ppt
David.
