WEBENCH® Tools/TPS92662-Q1: TPS92662-Q1
Part Number: TPS92662-Q1
Hi, is there a WeBench design or a CAD library file available for this part?
  • Hello Terry,
    I am not sure. But I will forward this to the correct people that will know what is available for this device.
    Clint
  • Hey Terry,
    I was informed that you have whatever access to the tools for this device already. If there isn't something there it probably isn't available. However if you need something further please let me know and I'll see what I can get, but I think part of the reason there isn't a tool is that it is relatively simple in its operation, generally the concern is the constant current driver. In either case I'm happy to help with whatever you need regardless. Let me know what questions you have an either I can answer them or I can find who can.
    Clint
  • Hi Clinton, there has to be at least a library file for the package, can I get that? Package is S-PQFP-G48.
    Thanks Clinton?
  • Hi Terry,
    Usually you can request this under the "Quality and Packaging" tab, but I do not see that option for this device. I will look into this and see what I can get you. You are right, there is an EVM, so there must be something available. I will let you know.
    Clint
  • Hello Terry,
    I was asked to remove this from E2E as this device should not be supported in this forum currently. But since you already have access to gated information you can send me a friend request here. Then I can share direct contact information and get you the IntLib file that way.
    Clint
