Could you check below question of gauging?
1. As i know there is charging counting function in fuel gauge. If charging is finish, does the number of count increase regardless of battery voltage ?
2. Generally, after full charging there is automatical discharge. So user does recharge. In case of recharge, does the # of count increase?
3. Could you share the detail document or equation which describe the calculation of FCC?
