hi team,
the ab max voltage for IFBx pins of TPS61196 is rated as 40V. I'd like to check the protection at below situation:
output is pushed to ~100V for many LEDs. if all the LEDs short suddenly, the IFBx voltage may go up to 100V. would IFB pin be damaged?
from the datasheet, it looks the device would remove IFB from the voltage regulation loop. However, the voltage at IFB may still reach 100V.
please help clarify.
thanks
BR,
Mike
