How can I connect 2 LM5145 modules as Master & Slave with common input and common output ???
Other Parts Discussed in Thread: LM5145
In SLAVE MODULE, is it necessary to connect the FB PIN to the VCC or should it be connected to the MASTER FB?
Should the COMP's MASTER PIN be shared with SLAVE?
There is an example schematic for this configuration??
