WEBENCH® Tools/TPS54540: ALTIUM: Model not found
Part Number: TPS54540
Other Parts Discussed in Thread: LM5576, TPS54531,
i have exported two designs from Webench to altium.
I get the following error Messages:
Model found in: C:\MyData\Simulation\SH220\TPS54531\WB_LM5576_BUCK_BLOCK_WB_TPS54531_BUCK_BLOCK_D1_ENCR.ckt
Model WB_LM5576_BUCK_BLOCK_WB_TPS54531_BUCK_BLOCK_D1 not found in file: C:\MyData\Simulation\SH220\TPS54531\WB_LM5576_BUCK_BLOCK_WB_TPS54531_BUCK_BLOCK_D1_ENCR.ckt
** WB_LM5576_BUCK_BLOCK.WB_TPS54531_BUCK_BLOCK.D1 Spice Model
** (C) Copyright 2017 Texas Instruments Incorporated. All rights reserved.
** This model is designed as an aid for customers of Texas Instruments.
** TI and its licensors and suppliers make no warranties, either expressed
** or implied, with respect to this model, including the warranties of
** merchantability or fitness for a particular purpose. The model is
** provided solely on an "as is" basis. The entire risk as to its quality
** and performance is with the customer
.subckt WB_LM5576_BUCK_BLOCK_WB_TPS54531_BUCK_BLOCK_D1_ENCR A K
.include pspice://../WB_LM5576_BUCK_BLOCK.WB_TPS54531_BUCK_BLOCK.D1.enl
XCALL A K WB_LM5576_BUCK_BLOCK_WB_TPS54531_BUCK_BLOCK_D1
.ENDS
also in
Model found in: C:\MyData\Simulation\WeBench\butterworth-filter\MAIN_BLOCK_CIRCUIT_FILTER_STAGE_1_SIM_A1_S1_WB_AMPLIFIER_MIRRORED_ENCR.ckt
Model MAIN_BLOCK_CIRCUIT_FILTER_STAGE_1_SIM_A1_S1_WB_AMPLIFIER_MIRRORED not found in file: C:\MyData\Simulation\WeBench\butterworth-filter\MAIN_BLOCK_CIRCUIT_FILTER_STAGE_1_SIM_A1_S1_WB_AMPLIFIER_MIRRORED_ENCR.ckt
Does anyone know a solution?
Best Regards
Rolf
