Part Number: BQ25504
I am new to PCB design and would like to ask following for BQ25504 reference design.
Q1. Why inductor L1 has to be as close as possible to the chip?
Q2. Why input tracks has to be thick lines?
Q3. Why there is a need for top and bottom ground planes? Will it work without ground planes?
Q4. For resistors and capacitors, is it ok if I choose larger or smaller size than 0805, as long as its values are as per data sheet recommendation?
Thanks a lot.
LB
