Tool/software: Linux
Hello
I have the BQ25898D driver from the Linux open source code, do you have a driver for the BQ25898?
any driver compatible for version greater then 3.19 will be suffice
thank you
Hello
thank you
Hi Ilan,
The bq25898 is the same as the bq25898D except the D+/D- pins have been replaced by PSEL and /PG and the I2C address is 1 bit different. PSEL is logic pin that performs very similar functionality as D+/D-. Therefore, the bq25898D driver can be very easily modified to communicate with the bq25898.
