Part Number: LM5008
Just powered up a new circuit using a LM5008 and the ripple voltage is excessive. Varied the load from 10-40mA, with little effect on the ripple.
Circuit and waveform attached, incorrect component? How best to troubleshoot?
Part Number: LM5008
webench_design_463344_708_446577639.pdf
Hello Jeff,
Recommend following the following design to meet your requirements.
See attached.
Hope this helps?
David.
David,
Thanks for that, R17 (Ron) was the problem, 20x improvement. I'm going to move the FB resistors close to pin 5 for good measure
