LM5060: Without OCP function
Part Number: LM5060
In my design, If we without OCP function , May I can change my circuit like below pic?
  • James,
    As always, recommendation would be to obtain an EVM and check your circuit and load conditions.  Assume you will have FET in place and use the FET for inrush only purpose with 24uA gate drive switching it via Crss or combined with a Cg to gnd.  You would presumably want Rs high enough so that 16uA * RS is >> diode forward drop. With that, you have OVP protection without PG function with some start up control.  I don't right off see an issue, but do check on an EVM.
    Brian
