Other Parts Discussed in Thread: TPS3808, TPS3890
Hello guys,
One of our customers is evaluating TL7700 for their new product. Then they faced a problem that /RESET signal repeated H/L level a few times when VCC goes down.
We have 3 questions as the follow.
Q1: Why SENSE pin voltage is not shift down immediately by the internal constant current source when /RESET is goes L level?
Q2: Our customer added this resistor (R163) to avoide /RESET H/L chattering and as the result, /RESET H/L chattering problem was removed. Is this countermeasure not problem for TL7700?
Q3: Is there any way to avoid the RESET signal H/L chattering except R163 addition?
I attached the customer circuit and several waveform of the problem.
Could you please take a look the attached file and please give me your comment and solution for the customer?
Your reply would be much appreciated.
Kazuya Nakai.
TL7700_Waveforms_Schematics.pdf
