I am planning to use LP3925 in my design. I have a couple of power supply load requirement which is more that what 1 LDO can support. Hence I am planning to combine 2 or more LDO outputs on PCB to cater for required load requirement.
Can I combine multiple LDO outputs together as I am planning?
What precautions should I take other than configuring for same output voltage levels?
Thanks & Regards,
Kiran
