SM72295: Recommended Pin Configuration when not using Current Sense Amplifiers
Part Number: SM72295
Dear TI Community,
I would like to use the SM72295 Full Bridge Driver in my new magnetic bearing amplifier design. Current measurement is done by a discrete device thus I don't need the two current sense amplifiers.
What is the recommended pin termination in this case. Do I leave all related pins (SIA SIA IIN BIN SOB SIB IOUT BOUT) floating or do I tie them to GND except for BOUT and BIN?
Thanks very much for your Help!
Kind regards, Michael
  • Hi Michael,
    Pins SIB, SOB, SIA, SOA, IIN, IOUT should all be tied to AGND since you're not using the current sensing features of this device.
    Happy Holidays!
    -Mamadou
    Applications Engineer, HPD
  • Hi Michael,
    I am an apps enginner for HPD also working with Mamadou and SM72295, I am curious exactly how you are using SM72295 in your magnetic bearing design?
    Could you possibly tell me some of you design constraints? or show me a snippet of where the SM72295 is being used in the schematic?
