BQ20Z45-R1: SEALED AFTER RESET
Part Number: BQ20Z45-R1
My BMU is stuck in a mode that puts it in seal mode every time after sending the reset command. What causes the BMU for getting stuck in the this mode and how can I revert back to being able to reset the BMU without sealing the pack
Steve
  • Hi Steven,
    If the pack has been sealed it will seal again after each reset and you must enter the code to get it back into it.
    Re-program with your file which is not sealed and you should be able to work with the pack until you are ready to seal again.
