We are using BQ25120 in our design which is very close to the production start. Just a few days ago our test group found the following problem:
BQ25120A will not charge a battery locked by PCM (over discharged protection), however it will charge properly if the battery is not discharged (over 3V).
Is it mandatory to replaced BQ25120 with BQ25120A to get this issue solved? Or is any known work around?
Unfortunately we have already built a good number of boards
Cezar
