Other Parts Discussed in Thread: LM25145, LM5145
The TPS40057 simulation has passed, and the PCB layout phase lacks detailed guidance. Can we provide PCB Demo for TPS4005x series products or provide guidance for wiring layout.?
Thank you
There are questions on the processing of SGND and PGND. Can you provide PCB Demo for reference?
I advise tying all Gnds of signal components to a SGnd using a poly pour and then route back to SGnd pin. Then Connect the SGnd pin to PGnd pin underneath the device.
Hope this helps?
David.
I think it depends on your design constraints you have set up or is a default in your PCB layout software?
I sent you an email to send me your layout.
Thanks.
