TPS7B63-Q1: Maximum open-window at Standard Watchdog Operation
Part Number: TPS7B63-Q1
Hi all,
I have a question on the data sheet.
Datasheet P.19 has the following description.
The watchdog service signal is not received during the open window. WDO is triggered after the maximum open-window duration t(WD) / 2.
I think WDO is triggered after the maximum open-window duration t(WD), because in Figure 25, it is written as t(WD).
Which of the maximum open window duration is t(WD) or t(WD)/2 ?
Koji Hayashi
