WEBENCH® Tools/TPS43060: TPS43060
Part Number: TPS43060
Hello, I was trying to design a 24 Volts output voltage and @19 Amperes. I used the Webench design tools but it can't generate 19 ampers output @ 24V.
I am using this IC TPS43060 to design my power supply.
Can anyone help to design a boost converter that can generate  24V output at 19Amps thanks.
here's my Specs:
Input 10V-12V Battery
Output 24V @ 19Amperes
  • You application is >400W, mostly requiring parallel MOSFETs to share the current. Webench does not support parallel MOSFETs. Please use the online TPS43060 design tool (Excel Spreadsheet) to help you design.
    Another option is, you may consider the LM25122 in multiphase. There several ref designs list under the LM25122 product folder.
