Other Parts Discussed in Thread: GPCCHEM, BQ24075
I'm starting with a charging/monitoring circuit shown below:
Note that the battery pack I need to use is configured as two cells in parallel. I understand from this post, that the two cells should self-balance during charging:
However, I'm unsure how the BQ27441 fuel gauge device will work. Can this device be configured to properly report charge level for a 1s2p battery pack? If not, can you recommend a suitable device for this application?
Note, the specific battery pack I need to use is:
