Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
5V from Microphone Phantom Power
Other Parts Discussed in Thread: LM5145, LM76002
I'm looking for recommendations/suggestions for obtaining 5V (for USB power) from 48V Microphone "Phantom" Power.
(nearly?) all Google results seem to be about doing the opposite; eg, this thread:
  • Andy,
    My experience with phantom power is that it's often derived from 5V/3.3V hence no need to create 5V because it's already there. That may be why it's difficult to find documentation on this use-case.
    We have lots of parts that can do this for you. LM5145 is a good 75V part that would get the job done.
    We can narrow down our portfolio if you can share your needs. Do you need:
    • Fixed frequency
    • A particular switching frequency
    • Good light-load efficiency
    • Other care-abouts...
    Let us know and we'll find something that fits.
    -Sam
  • Hi Sam,
    Thanks for the reply.
    The application would be at the microphone end of a microphone cable - so no other supplies available!
    Good light-load efficiency would, indeed, be key - as there is only very limited power available anyhow.
    As it is a microphone lead, low noise would also be good!
  • Andy,
    Check out LM76002. That's a 60V part with plenty of current. It has 15uA Iq and it's a QFN so it should be better for EMI.
    -Sam
