Part Number: TPS7A8001
Dear linear regulator team,
could you please help to check whether TPS7A8001 Pin 4 and thermal pad of TPS7A8001 are connected together inner IC?
as described in datasheet, PIN 4 and thermal pad are both ground. but in customer's test, LDO output voltage is abnormal when only thermal pad of TPS7A8001 is connected to ground.
Thanks in advance.
best regards,
Yang
