Other Parts Discussed in Thread: BQSTUDIO, BQEVSW
We have created the golden image files for the fuel gauge with the battery used in the system.
We need a clarification on the BAT_LOW/BAT_GD pin configuration. We would like to use the Pin 12 as BAT_GD and the polarity we wanted for the pin is Low. So we have set the LSB byte of the OP Config register as B (GPOUT_POL=1, GPOUT_INT=0, BAT_FN=1, TEMPS =1), But we have seen BAT_GD going only Low only if we write the GPOUT_POL bit as 0. But using the bqeasy (0.9.92 version) tool we are not getting an option to make that bit as 0. Can you please let us know how do we set the bit.
I have attached the .ezy file and .gg files.
Ravi
