Other Parts Discussed in Thread: BQSTUDIO, GPCCEDV
Hi
We are trying to get a BQ34110 programmed and creating a golden sample for manufacture.
Is there document describing the procedure/steps from beginning to end that we can follow?
There seems to be a lot of loose information available, but we keep getting stuck, not knowing where we are going wrong.
E.g We do not know exactly which values in BQStudio Data memory needs to be changed and during which stages of the process.
E.g question: Is appears that sometimes we manage to change a value, but other times the value goes back to it previous value. Is there an order in which changes are to be done?
Our battery details are: 10 cells NiMh all in series, 4.5Ah. Cells are 1.2V.
Currently we update our EV2300 from 1.3c to 1.3m and find that we cannot update data memory.
We get an error message; "No parameter matched address" (?)
Thank you for your help.
Eduard
