Dear Sir:
According to the TPS650942 datasheet, the switching frequency of buck 3 is 1.7MhZ at vout 1.05V.
may i know 1.7Mhz have any tolerance,
I use short pin for probe to measure, The current amount of switching frequency of about 1.3Mhz.
Dear Sir:
Hi Wang,
BUCK3, BUCK4, and BUCK5 are all DCS-control converters with a heavy emphasis on transient response and optimal PFM-to-PWM transition. More detail on DCS-control is available here:
This control scheme does not have a fixed frequency. It can vary based on VIN, VOUT, IOUT, inductance, capacitance, and even parasitic impedances. As a result, we generally test the frequency on our EVM and list that as the "typical" but there can be variation board to board. Seeing a switching frequency of 1.3 MHz does not indicate that there is a problem with the circuit.
