TPS22912C: need more robust device
Part Number: TPS22912C
Using the TPS22912CYZVR in production.  Seeing possible issue with ESD sensitivity.  Is there a device with higher ESD rating?
  • Hi Diane,
    The ESD ratings for the TPS22912C are pretty standard for our load switch devices. Do you know what ESD rating you are looking for? Also, is this system level ESD (when the device is on) or device level ESD (when the device is off)? Our ratings are obtained when the device is not powered.
    Alek Kaknevicius
