Part Number: TPS54060
The datasheet recommends a 0.1uF value for the bootstrap cap. In my current implementation, SW node is pre-biased because my output has a battery and my Vin - Voutis not very high (~ 3V). At lighter loads, I see a n operation where it appears that the part is switching for a while, then shuts-down for a short duration. This behaviour is periodic. It can be reduced and. consequently, eliminated by increasing load current or by increasing Vin - Vout.
That leads me to believe this is a ' bootstrap cap not having enough charge ' issue. Do you agree?
As an experiment, I reduced the value to 0.02uF and noticed a significant improvement. Do you foresee any adverse effects in operation over time by reducing it to this value?
