UCD90160: Can't find logged peaks with Fusion software
Part Number: UCD90160
Using TI Fusion to debug a system. The older version of this software (2.0.5 if think) could access logged voltage peaks from the chip. I would like to do this to determine which voltage went out of range to cause the system to shut down. I can't find how to access logged peaks in the newer version of Fusion. I know it can log real time voltage levels to a file, but I need the logged peaks from the chip after connecting. I can't connect until after the power up fault because the connection prevents me from powering up.
